Message 1 of 7
Folders
I seem to have deleted a folder.
Can this be retrieved?
6 REPLIES 6
Message 2 of 7
Re: Folders
It should be in your Trash folder as long as you have not empied the Trash folder.
If it is the click on the small arow next to the Trash folder and that will allow you to restore it.
If you have emptied the Trash folder your folder can not be recovered.
Message 3 of 7
Re: Folders
Thank you, Distinguished Sage.
Haven't emptied trash, lots of individual e-mails still in there, but no sign of the folder in question.  Even tried using the "search" facility with no success.
Message 4 of 7
Re: Folders
Look around the Trash folder name and if there is tick or similar click on that.
It looks like an upside down v
Message 5 of 7
Re: Folders
Have had a really good look in trash, without any success.
Must have double deleted it??
Thank you for your help and suggestions
Message 6 of 7
Re: Folders
Have a look for the small arrow and click on that.
Message 7 of 7
Re: Folders
Thank you for your perseverance, no joy there either
