Message 1 of 15
Having difficulty accessing BT mail,
  • Trying to change password to email app on android, will not accept, am I correct in thinking I also need to change password on my tablet
14 REPLIES 14
Message 2 of 15
Re: Having difficulty accessing BT mail,
Have you been able to login to your email yet? I'm not able to access my emails on the BT app but can through the website. Hopefully this is just a technical issue that is being sorted out?
Message 3 of 15
I'm having the same problem. Cannot access emails on the BT app.
Message 4 of 15
Unfortunately no, I'm accessing from the Web page
Message 5 of 15
I am also having similar issues with the app. Looks like a BT wide problem.
Message 6 of 15
BT email app login error
My BT email app on all my android devices no longer recognises my login details. I know they are correct as I can log in to email accounts through the website without difficulty. I have reinstalled the app, changed the passwords but no luck. This only started last night. Is there currently a fault with the app.
Message 7 of 15
Re: BT email app login error
I'm having exactly the same problem
Message 8 of 15
Me too
Message 9 of 15
I'm having the same problem. I've messaged BT on X and they are looking into it.
Message 10 of 15
OK. I thought it was just me at first
