Message 1 of 15
How do I setup a DKIM record with BT
Hello,
I'm trying to solve the never ending issues of bounced emails when emailing from btinternet.com with a custom domain to gmail people.
I've setup the SPF as follows on the custom domain as a TXT record. It is the only SPF record.
v=spf1 include:spf.protection.outlook.com include:btinterent.com -all
But I can see in the header of emails send from my dad to me...
Received-Spf: permerror (zohomail.eu: Error in processing SPF Record) client-ip=213.120.69.111; [email protected]; helo=re-prd-fep-045.btinternet.com;
So I'm not sure my SPF is setup correctly.
Also, do I need to setup a DKIM record/signiture... but do I do this with BT Mail.
Thanks!
Dom Boston
14 REPLIES 14
Message 2 of 15
Re: How do I setup a DKIM record with BT
Message 3 of 15
@dominicboston27 if that's a copy and paste of  your SPF record, you have a typo in the record.
Try
v=spf1 mx a ip4:213.120.69.0/24 a:btinternet.com  ~all
Message 4 of 15
Thanks, will try. Isn't that IP address going to change?
Message 5 of 15
No, it's the address range of the BT email servers.
Works for me using Ionos.
Message 6 of 15
Nice, thank you. I thought the include:btinternet.com should have fixed it tbh.
Dom
Message 7 of 15
I thought likewise (I knew nothing about "SPF" first thing this morning but I'm learning a lot  🙂)
However,"liquorice" kindly posted this link elsewhere :-
https://flowmailer.com/en/resource/dissecting-the-spf-record
And that says that the "include" should refer to the domain where your SPF record is specified.
Just adding the details above to my DNS didn't seem to work for me but then I added an "Include" with my domain name (as below) and (so far !) I think it has worked.
v=spf1 mx a ip4:213.120.69.0/24 a:btinternet.com include:<my domain name>.com ~all
Many thanks to "liquorice" 🙂
Message 8 of 15
You can test it by emailing and checking the message headers 😊
Message 9 of 15
@licquorice  this is still failing
Received-Spf: permerror (zohomail.eu: Error in processing SPF Record) client-ip=213.120.69.122; [email protected]; helo=re-prd-fep-046.btinternet.com;
I will try @jeremygoodall approach
Message 10 of 15
@jeremygoodall
Thank you, this was the solution that worked. I think that the important bit was the last bit, as I had the other parts in before it worked. include:<my domain name>.com
