Message 1 of 11
How to open emails from a tower from one location which is now connected to my hub
My relative had a serious illness. So their tower from their home is now in mine and connected to the back of my wifi hub. I tried unsuccessfully to access the emails with the correct username and password. Is it possible to do this,
10 REPLIES 10
Message 2 of 11
Re: How to open emails from a tower from one location which is now connected to my hub
Not entirely sure what you mean by 'tower' and why you have it.
You don't need any of their devices to log in to email. Email can be accessed from anywhere by webmail.
Message 3 of 11
If by "tower" you mean your relative's computer, then this normally does not hold any of your relative's emails. They are instead held on BT's servers and you can access them via BT's webmail system, if you login in using your relative's email address and password.
Be aware though that BT has now introduced two factor authorisation and will probably want to send a text with an access code to either your relative's mobile phone (if the relative has already set this up) or to a mobile phone that you can specify (if no mobile phone has already been set up)
Message 4 of 11
Hello chrisjp,
Thankyou for your answer, unfortunately I still could not log in. When trying, the username and password boxes wer stored. But  A friend tried as well which also it did not work. they looked at the cache and then manually entered the password without success.
Any thoughts
Message 5 of 11
While this is most likely a genuine plea for help I would suggest that the forum should not be assisting some unknown person to hack into another person's email account.
If you are looking for assistance to get into the email account you will need to contact BT 0330.1234.150 and see if they will help.
Message 6 of 11
I agree that it's a bit questionable to provide help to someone who is effectively hacking into someone else's email account.
However, I suspect that if the OP calls BT to ask for help, he'll be told that BT must speak to the BT account holder to make any changes and I guess this won't be possible if the account holder is seriously ill.
My previous answer was given on the basis that the OP has his ill relative's full consent to access his email and maybe the OP should double-check with his relative that he has the account login and password details correct.
Message 7 of 11
I agree that the OP may have the full consent of the BTMail account holder but we only have his word for that. If he goes through BT they can ask more detailed and verifiable security questions.
Message 8 of 11
Hello everyone,
To answer your discussion, My brother has had a stroke and lost mobility and speech.
I am not very clued up with computers and thought that there must have been a simple answer to my problem.
I appreciate everyone's concerns, I shall contact BT when my LPA is approved.
Many thanks
Message 9 of 11
The simple answer is you don't need anything from your brother's house to access his emails.
All you need is his email address and password and you can just access them from your PC/laptop/iPad/ whatever.
Just go to the BT email login page and e ter the details.
https://www.bt.com/help/email/bt-email-login
Message 10 of 11
Hello again,
I have seen you replies and it does not work. As in my previous  reply on 23.-05-2026 19h24...............
Many thanks
