Message 1 of 53
I am unable to send emails, they get stuck in my outbox.
I am unable to send emails via my BT account. Using BT web mail I recive a message Too many messages (2.4.6.3) if I use an ipad or iphone I get a message Cannot send mail, the connection to the outgoing server "mail.btinternet.com" failed. Does anyone know how to resolve
52 REPLIES 52
Message 2 of 53
Re: I am unable to send emails, they get stuck in my outbox.
Hello @markg123.
Are you trying to send an email to multiple recipients?
Speak soon,
Katie
Message 3 of 53
I have found out the issue related to a change BT made in security. It is now resolved
Message 4 of 53
Hi ,
can i ask what the resolution was . I seem to have a similar issue
thanks
Message 5 of 53
I am also having the same problem.
I use Outlook, and have tried clearing out old email, etc. The problem seemed to start suddenly (midway through sending a few messages), and I can't send via any app or webmail.
Could someone let me know the solution to this, please?
Message 6 of 53
Morning @MartinTatham
Welcome to the community 🙂
Do you get an error message when trying to send an email?
Could you try the advice in our BT Email: I can't send or receive email, does this work for you?
Speak soon.
Leanne.
Message 7 of 53
The issue is with BT, they brought in a safety measure which means if you change your password you will have limit capability to send emails for 7 days. You cannot send any for 24 hours. This may also occur if you try and send emails to a group of greater than 40. The reason given to me was that they are trying to stop spam mail when your email maybe hacked. It would also appear if you are overseas BT, using AI, may think your email has been compromised as it is using an unknown  area and will ask you to change your password. During the quarantine period you should still be able to receive emails. I hope this helps
Message 8 of 53
@markg123
I suspect you have been given a load of BS and flannel.
If BT limit your sending of emails for 7 days that implies they are in effect happy for a hacked account to be used/accessed for 7 days by the hacker who compromised your account and managed to change the password or else it means they are happy to punish you for changing your password for what ever reason you changed it. ie routine security advice to change passwords.
The limit for sending group emails is 100 so why take exception if you send 40.
There have been some cases on the forum when an email account has been used, usually when a public wifi hotspot was being used locked when abroad but in all the years I have travelled abroad to various countries I have never had an issue and I am sure that is the case for most BTMail users otherwise I would have expected many many more reports on the forum.
In fact I am abroad at present and my email account is working without issue.
I would also expect BT to have announced these "security" changes if they are in fact genuine.
Perhaps a moderator could seek clarity on that and post here if it is the case.
Message 9 of 53
Your comments are valid and I said exactly the same to BT about working from overseas and having a limit of 40. As I have not incurred this before when overseas and had often sent bigger  emails. However, I was told they had recently made the changes and was sent a copy of an internal memo confirming the new security protocol when you change your password. Also I was told in the small print they only guarantee emails in the UK not overseas and that  a group of 40 in one email was the maximum advised, although it may work with higher. The hacking would not be possible as your account would be frozen until you changed your password.
Message 10 of 53
I understand you are only passing on what you were told but it does not make sense.
As regards the hacking, the whole point of a hack is your password has been compromised and as such the hacker has access to the account.
The hacker may not change the password but if he chooses he can change it preventing you,the person who was hacked from gaining entry to your account in order to change the password.
This is assuming you are aware it has been hacked meanwhile the hacker can use your account a steal your contacts,bank details etc.
The one thing I never took in to account was that this "new" security measure was brought in by BT so it will of course be flawed!
