Message 1 of 4
Inbox folders
I have mistakenly deleted an email folder is there any way I can recover it.
3 REPLIES 3
Message 2 of 4
Re: Inbox folders
It will probably be in the trash folder.
Message 3 of 4
Re: Inbox folders
Folders do not show in the main section of the Trash folder. You will find deleted folders in the Trash folder by clicking on the > arrow to the left of the Trash folder.
When you find the folder just drag and drop back to where you want it.
Message 4 of 4
Re: Inbox folders
Hi gg30340, you have solved my problem the folder is back where it was.
Thanks for the answer and very quick response
Al74
