Message 1 of 4
Latest changes to e-mail format
The latest e-mail format does not fit ion my computer screen. The dates are offscreen and the e-mail address at top right also off screen. Have been in touch with BT with great difficulty and they say I should come on here for a solution as they can't change the format. They also suggest I check Privacy, Searches and Service settings . They say they suspect I have it set to Strict when balanced should be adequate. I have no idea what they mean by this. If everything was ok with the old e-mails then surely this changeover should make no difference. I have to also add that that I relly dislike the Capital Letters in the boxes, they add nothing only confuse.
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Latest changes to e-mail format
You can turn off the "coloured" squares by going into the settings found by clicking on your username at the top right then click on settings then Mail in the left hand column then untick the box "show avatar in the message list".
You should try reducing the size of your web page by either going into the web browsers settings and adjusting the zoom or by using your key board by pressing Ctrl and - (minus) keys.
Message 3 of 4
Can't get to settings because it's off the screen. Will try what you suggest about reducing screen size but my bugbear is with BT. Everything has been fine even with their previous changes but now having problems with this latest change which they don't want know about. According to them its my problem to sort and suggested the forum for help.
Message 4 of 4
Removal of "coloured boxes" worked. Use of Ctrl and - key also worked. This allowed everything to fit onto screen. Only problem is that by reducing e-mails to fit makes them very small to read which is not ideal. Any suggestions? Thanks for the previous help.
