Message 1 of 16
Legitimate emails 'lost' by BT server
To my mind, the problem that I am having with BT's Email handlers renders their email system UNUSABLE.  Unfortunately, my BT email address is very much ingrained into my life, and I would much rather get the issue fixed, rather than run away from it.  There are two aspects to the issue:
  1. I cannot rely on messages that I send out to long-standing and legitimate email addresses being  posted on to the intended recipient with 100% certainty.  I only have one such recipient that I can prove with 100% certainty, but then I don't know what I don't know, and there may be more!  They just get totally 'vaporised' without any warning message to me or to the intended recipient - not branded as SPAM, not sent to 'Junk', just totally vanish!
  2. I cannot rely on legitimate messages sent to me reaching me with 100% certainty either!  I had a run-in with BT on this particular aspect in the Summer of 2023, when I suddenly stopped receiving very important emails from a Club; other members of the Club continued to receive them, and I only found out about the problem by chance.  I was in a position to trace those messages, and their path ended abruptly at the BT Email server.  Not in Spam, not anywhere, just 'vaporised', as I describe it.  BT fobbed me off with platitudes about 'protecting the safety of their customers' and they just would not accept that if their checking algorithms had any doubts about the message, then they should modify the Subject line with a warning, and send it either to my Inbox or to Spam - AND MOST CERTAINLY NOT just make it totally disappear without trace.
In addition to the issues above, an important  message that our Health Centre sent to my wife completely vanished before it reached her, and just today I actually watched someone send me an emailed receipt / confirmation of a booking that I had just made / paid for, and that email has also vanished without trace!
I cannot think that I am such an odd case that I am alone in suffering from these problems.   I thought I'd ask whether anyone else on this forum is aware that they are affected?  I am so annoyed with this matter that if BT cannot be persuaded to change their practice, then I am minded to bring it to the attention of every TV and Radio Consumer Programme that I can think of.
15 REPLIES 15
Message 2 of 16
Re: Legitimate emails 'lost' by BT server
I have also lost emails, 4 that I know of in the last month.  With my husband we have 3 email addresses and all of them are affected.  They are all local to our address and one is from a local bank. As it happens, we are moving house and the other 3 missing emails are quotes from removal companies.  I tried BT email technical help but after an hour and a half the problem is not solved.  I am so frustrated by this and will look at other options once we have moved house.  Sorry I can't offer a solution but I wanted to let you know you are not the only one in this situation.
Message 3 of 16
Thank you!  I suspected that I couldn't possibly be alone, and now you have confirmed it!  I think that I will start phasing out my dependence on BT Internet emails unless their Technical team decides to take notice of our complaints by changing its filtering algorithms and practices.  I am not asking much of them - just send messages they don't like the look of to SPAM, rather than into oblivion.
Message 4 of 16
@Cougar_Kid
did you read this posts about problems and fixes done or still to be done   https://community.bt.com/t5/Email/BT-Webmail-Feedback-v2-post-16th-April-release/td-p/2376642
why don't you put the problem emails in safe contacts
Message 5 of 16
Thanks for the link - I'll try it.  I couldn't put the contacts in 'safe contacts' because I haven't had any emails from them previously so don't have their addresses.
Message 6 of 16
Hello
Thank you for your comments - but they don't get anywhere near answering my problem.
The link that you kindly provided focusses on what are essentially cosmetic attributes of the webmail service: my problem is at a deeper level, and involves the algorithm that the BT Email service uses to inspect and route messages that pass through it.  Incoming messages should either be sent to my inbox, or, if the algorithm thinks the message is dubious, to Spam.  My problem relates to messages that don't go to either of those destinations - they vanish completely.  I know how to mark messages as 'Not Spam and Safe Sender' - but of course I can only do that if I find them in Spam.  If they have completely vanished then normally I have no alert to that fact.  "I do not know what I do not know."
Both the Club messages that I referred to and the friend who suddenly stopped being able to send or receive emails to / from me were already registered as 'Safe Senders' when these incidents suddenly arose.  For my friend, I have simply given up using BT Internet emails, and I use my 'gmail' account instead.  No problems since I changed to that practice.   For the important Club messages, I did get some pointers from the BT Technical Team that the messages were failing to reach me because the Email Service that the Club used - one that is widely used by Bridge Clubs throughout the UK and some in the wider world - had been listed on the Invaluement international list of blocked domains.  I took it upon myself to contact Invaluement directly, with sufficient supporting evidence to persuade them to de-list it.  As soon as that was achieved, the messages from that Club flowed to me freely through the BT Email Server.
My primary point is that it shouldn't matter whether or not messages come from a 'listed' domain.  If BT want to raise red flags by sending it to SPAM then at least I have an alert that I can act on.  I have ZERO confidence that all sorts of other important emails that have been directed to - or, indeed, from - me are not being subjected to the same action, and finished up in oblivion.  "I do not know what I do not know."
Message 7 of 16
The BT spam filters categorise mail in one of three ways. Mail they consider ok goes to the Inbox, dubious mail goes to the Spam folder and anything they decide is definitely spam is rejected at the server. If the latter were not the case, your Spam folder would be inundated with thousands of spam mails daily.
Unfortunately, the BT spam algorithms are not the best and quite often the baby gets thrown out with the bathwater.
This has been the case for a long time and I despair that they can't get it right when others seem to be able to do so.
I have long since used Gmail for any important emails.
Message 8 of 16
Well that is very clear!  Thank you!
Do you not have problems using gmail for Banks, Credit Cards, etc: they seem to want an email address that can be tied to a real and verifiable street address?  Mind you, as far as I know, I have never had issues with messages from such institutions coming to my BT Internet email address.  As far as I know........
Message 9 of 16
No, but I can't see how a bank or any other institution can tie an email address to a physical address, that's entirely impossible.
Message 10 of 16
How can a bank want an email address to be tied to a verifiable street address.  How would they know the email address was tied to that address.
To open a bank account, you need to provide proof of your identity and address. This can include a recent utility bill, council tax bill, rental or mortgage contract, bank statement, or a benefits or state pension letter.
There is no requirement to provide an email address. Not everybody has one.
For online only banks you require the above and an email address but there is no requirement to prove it is tied to the street address. How could it be proved.
