Message 91 of 175
Re: Links in emails not opening in new browser tabs
What is a 'middle button'?
Message 92 of 175
Typical BT ; not interested in making life easier for customers.
Message 93 of 175
If it ain't broke don't fix it.
Message 94 of 175
Oddly enough it is the button in the middle between the left and right buttons. Usually doubles as the scroll wheel.
Message 95 of 175
But it IS broke, and they're gonna fix it! 🤣
Message 96 of 175
My laptop keyboard does not have a wheel.
Message 97 of 175
Quick suggestion in case it's helpful to anyone who is being driven mad by the issue.
Instead of clicking a link in the email preview pane, open the email (quick double-click), which opens the message in a pop-put window. Click the link from there, then, when finished, close the pop-up window, and you are back to where you were in the inbox.
Still not ideal, but very slightly less time-consuming and cumbersome.
Message 98 of 175
And I meant 'pop-out' obviously.
Message 99 of 175
Thank you that is very helpful. Like many others it is just getting used to using these work arounds when BT email users have had links automatically open in a new tab for years.
Message 100 of 175
I agree completely. I'm still only remembering to do the work-around about one in about times.
