Message 1 of 3
Locked out of email and unable to access pin
Hi there,
I am currently unable to log in to my email due to 'suspicious activity', so therefore am unable to access the recovery pin. The security question answer escapes me and I am currently working abroad and unable to call the help centre does anyone know of a way that I can regain access to my account?
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: Locked out of email and unable to access pin
There is no way to by pass the security of your acount.
You need use the prescribed methods either calling BT and answer the security questions or the PIN method.
Once you do gain entry you should log onto your MyBT and set up an alternative email address such as a gmail address as your recovery email address so as to avoid this in future.
https://www.bt.com/help/email/manage-email-account/i-need-to-change-or-reset-my-bt-email-password
https://my.bt.com/s/apps/appsselfserve/index.html#/forgotPassword
Message 3 of 3
Thanks so much, I was hoping that there wold be another security measure that I might have been able to use
and yes the recovery email is definitely going to happen!
Thanks for your help!
