Message 1 of 15
Mail Apps
Moved to a newbuild and couldn’t take BT services as OFNL connections only. Paid for BT Premium email to continue my email access etc. Virtually on changeover day bt mail started playing up on all of my apple devices and wouldn’t connect through the apple mail app. I’ve checked with Bt and my account seems ok and I can confirm premium status. Am failing to reconnect my BT email via the apple devices. Anyone got any similar experience or advice, (not too technical please !)
Webmail is working fine.
Every one of my apple devices won’t recognise the Bt mail account even though apparently my account is confirmed by BT and my username and passwords are being input accurately.
Using BT mail app as an emergency but I really would prefer to reinstate my apple mail app asap.
14 REPLIES 14
Message 2 of 15
Re: Mail Apps
Hi @Musicman60,
Welcome to the BT Community
Sorry to hear you are having an issue with your email in Apple Mail after your move to premium. When you mention failing to reconnect your account to the Apple mail app, have you checked the email server settings are all correct and have you tried re-adding the mailbox to the app with those settings?
Can you login to the BT Mail app or does that not work? As if you cannot it does suggest there could be an issue with the premium on your account.
Alex
Message 3 of 15
Re: Mail Apps
Hi Alex
really appreciate you getting back to me. I was a long time BT customer with excellent broadband and email access. I used the Apple mail app very successfully over that time. I moved house and Openreach didn’t connect to the estate so I had to give up my BT broadband package and use an OFNL provider. I opted to retain my email on the premium plan and carried on my direct debit. When I ended my service with BT the problems with the email on the Apple app started. I’d get slow connections and eventually it just stops working. I have several emails on my Mac that remain unopened as I can’t load my email address onto it. Webmail is fine as is the BT App, I just found the Apple app really user friendly. As far as I can tell everything is set ok, it is just when I try to reload my details onto the Apple app that I’m unsuccessful. B
Message 4 of 15
Re: Mail Apps
@Musicman60 Yeah if you have premium you should definitely be able to use the mail client you want rather than being restricted to webmail, if you have been able to use the BT Mail app it does sound like premium is activated.
When you say you are trying to reload your details, what exactly do you mean? And are you getting an error message at any point, if so what is the error message?
It would be worth updating your BT Mail password, then wait a little bit and then update the password in your Apple Mail server settings to see if this allows them to resync.
Alex
Message 5 of 15
Re: Mail Apps
I suspect the problem lies with Apple Mail, to verify you could try using a different third party app such as Blue Mail.
Message 6 of 15
Re: Mail Apps
Hi again, really grateful for your input. I’ve deleted and reloaded the Apple mail app. On the first screen I input my email details and am taken to an input screen asking for my name, email and password. The bottom of the screen is defaulted to ‘description Btinternet’.  The screen then buffers as ‘verifying’. I then get a message saying the IMAP server mail.btinternet.com is not responding . Check your network connection and  that the correct information is entered in the incoming Mail Server field. My internet connection and broadband is excellent and  the information/password etc I have entered is accurate. B
Message 7 of 15
Re: Mail Apps
Thank you so much for taking the time to consider my issue. My Gmail account works well with the Apple mail app. It’s just the BT mail that’s the issue and only occurred once I changed business terms, i.e. left BT broadband and kept premium email. Something has occurred, I assume, on that transfer from ‘normal’ mail as a full account holder/customer to solely a premium mail subscriber. B
Message 8 of 15
Re: Mail Apps
Finding the source of the problem requires a logical faulting process. To rule out Apple Mail being the source, temporarily trying a completely different mail app will assist in this process. If the third party app works, the problem clearly lies with Apple.
Message 9 of 15
Re: Mail Apps
Thank you for that advice. I’ve just tried Bluemail and funnily enough had a similar reject in that Setup could not finish due to the server not responding. So I’m at a loss and even more confused as to what the issue could be now. B
Message 10 of 15
Re: Mail Apps
In that case it points to a problem at BT Unfortunately you will need to get them to investigate.
I could be wrong, but I don't believe the BT mail app is a true mail client, rather it is just a different front end GUI of webmail masquerading as a mail client hence it is not accessing the same servers real clients access.
