Message 1 of 6
Mail issue
Any Help with this appreciated:
As of today when opening mails a seperate preview pane opens instead of opening the mail directly, The preview pane is headed Mozilla firefox, I then have to view the mail by clicking the preview pane, which is annoying to say the least! I don't know if this a BT thing or something I may have done inadvertantly.
Any suggestions appreciated
5 REPLIES 5
Message 2 of 6
Re: Mail issue
Hi @jaret139
Thanks for coming back to the community.
Could you try deleting cookies and cache and opening a web browser, does the same happen?
Have you tried a different web browser?
Leanne 🙂
Message 3 of 6
Re: Mail issue
Click on the View button on the right hand side ans select "No Preview".
When you want to read the email just use a single click not double click.
Message 4 of 6
Re: Mail issue
Thanks so much for that! Problem solved.
Message 5 of 6
Re: Mail issue
Thanks for your response Leanne, problem solved!
Message 6 of 6
Re: Mail issue
Thanks for letting us know @jaret139
Have a lovely day 🙂
Leanne.
