Message 1 of 7
Microsoft verification code
I have tried many times but i am not receiving to my email address passcode to reset my password. How does one resolve this?
6 REPLIES 6
Message 2 of 7
Re: Microsoft verification code
Hi @LB21
Welcome to the Community
Are you receiving general emails as normal? Are you able to receive Verification Email codes from any other companies or services?
Ali
Message 3 of 7
Ali
I am no issues with anyone else
Message 4 of 7
@LB21
As it's only Microsoft codes you're having a problem with, it may be worth having a look at their Troubleshooting verification code issues page.
Ali
Message 5 of 7
I started getting this a day or so ago when using Edge because I couldn't log in using Chrome (That's another unsolved problem)
The guide (for once knew what he was talking about) said that 2FA was being rolled out for all users without telling them.
To switch it off,  log on to MYBT     Hover your cursor over the   MY BT   Tab.    Choose     Personal Details  under     My Details
Scroll down past your  Personal Details, and you will see the option to switch it off as I did, and it worked.
Two-step authentication
Increase security on your account by receiving a unique passcode when you log in to BT apps and services on a device. You'll need to re-log in to your BT services when you set up two step authentication.
Two-step authentication is currently OFF
Message 6 of 7
How does having BT's two step authentication turned on to prevent unauthorised access to BT accounts stop verification of a Microsoft account?
Message 7 of 7
As a heads-up on part of this, Microsoft Authenticator is being decommissioned.  That, combined with some odd secure browsing behaviour in Microsoft Edge, is beginning to cause some issues for some people.
*If you are using edge, even with secure browsing turned off, and supposedly using the default system DNS, it'll still use a combination of Google and Cloudflare DNS.  Noticed while checking different browsers to see if my ad filtering was working!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
