Message 11 of 16
Re: Moving emails to sub folders
Its a nightmare - the other thing you need to watch out for is that once you have moved or deleted an email the system automatically highlights the email next email down, so if you don't notice and highlight another email to move or delete it, the system automatically deletes or moves the one it has highlighted - Before I realised this was happening I kept losing emails and then accusing people of not replying saying I hadn't received emails when they had sent them. The system is far from user friendly on a PC - mostly I end up resorting to dealing with emails through my iphone or ipad.
Message 12 of 16
Presumably using a mail app. Here's an idea, why not use a mail app (client) on your PC instead of webmail. Thunderbird and EmClient are both free.
Message 13 of 16
To stop the next email being selected when moving or deleting an email go to the settings found by clicking on your user name at the top right then go to “Mail” in the left hand column. Then in the General Settings untick the box “View next mail after delete/move”. Then click “Save”.
Message 14 of 16
I normally just drag the email to the folder listed on the side but did try move to and yes the sub-folders disappear.
I then tried using the down triangle at the top of the opened email and it worked that way.
Message 15 of 16
thank you - that has solved the problem
Message 16 of 16
I am logging into email through the BT website
