Message 1 of 6
Moving from BT to another provider - can I keep my @btinternet.com email address?
I'm considering moving from BT to another provider (due to costs). If I do, can I continue using my @btinternet.com email address?
5 REPLIES 5
Message 2 of 6
Re: Moving from BT to another provider - can I keep my @btinternet.com email address?
Message 3 of 6
Thanks!
Message 4 of 6
Be aware that once you leave BT Broadband your BTMail will only work with a web browser. It will not work with email clients or email apps such as you may use on mobile devices.
See link
https://www.bt.com/help/email/bt-email-products
Message 5 of 6
But be aware that you can pay a monthly subscription to keep the "premium" email service, which can be used with email clients and apps
Message 6 of 6
As is shown in the email products link that is posted in the above message 4.
