Message 1 of 3
Network Connection
looking for some advice here please.
updated and installed the BT mail app on my iphone.
when i log in it says
Network Connection
internet connection is not available. pls switch on wifi or mobile data
But the thing is
wifi / data are both on and working
i can use the same BT account on my desktop
Any pointers please ?
thanks
2 REPLIES 2
Message 2 of 3
Re: Network Connection
The best advice is to remove the BTMail app which is pretty poor, and just use the Apple Mail app that comes pre installed on your iPhone.
Message 3 of 3
Sorted ! Much appreciated
