Message 1 of 2
No Longer Able to Receive Kickstarter Emails
I haven't received an email from Kickstarter since mid-May, despite the three projects I'm backing sending out regular updates. I've checked blocked domains and Kickstarter definitely isn't listed there. Can anyone advise?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: No Longer Able to Receive Kickstarter Emails
its likely bt blocking the doman by default sometimes theres nothing   you can do change email and see if you get updates
tip keep bt emails for account related contacts amd switch everything to anther email or it least anything thats not getting through
