Message 1 of 6
No send button for Reply
With the new webmail, when I reply to an email the send/discard buttons appear briefly but then disappear and only the Save Draft option is offered. I have tried logging off and on, and sending from the drafts folder - no luck.
5 REPLIES 5
Message 2 of 6
Re: No send button for Reply
My OH and I both have this problem, too - can anyone help out?
Message 3 of 6
What type of device are you using?
What operating system are you using?
What web browser are you using on that device?
Have you tried a different web browser?
Message 4 of 6
MacBook Pro, Ventura 13.6.1, Safari, No
However, the problem has now gone away.
Message 5 of 6
I still can't send email from drafts.
Message 6 of 6
Oh gosh - how rude of me not to have replied - have been mostly off grid in Central America. But back now and the problem has reappeared when using Chrome on a laptop. It works okay on my in Firefox and on my iPhone 13 using the BT app. So there's a way round it, but I'm generally on Chrome so it is pretty tiresome and if you know how to cure it, that would be fab.
