Message 1 of 5
No suggested email when name typed into address box
Suddenly the address box does not give the suggested email when I type in a name. Plus my inbox is showing 20000 plus emails, most of which I deleted years ago.
4 REPLIES 4
Message 2 of 5
Re: No suggested email when name typed into address box
Fixed the address problem in settings. Enable Auto-Complete Search for some reason unticked - not by me!
Still 20000 previously deleted emails in box. Will take forever to delete at 50 a time!!!!!!!
Message 3 of 5
Deleting multiple emails has been posted on the forum many times already.
If you want to delete multiple emails try the following.
If you hold down the shift key then tick the box to the left of the first email you want to delete in the list of emails then scroll down using the scroll bar on the right hand side and then tick the last email you want to delete then release the shift key. It will select all the emails in between.
If you don't want all of them deleted you will need to go through the list and untick the ones you want to keep.
You can then click delete or drag and drop them into the Trash folder.
Message 4 of 5
The problem is that these have all been deleted from inbox and trash before and have now reappeared in my inbox.  It has happened before and I cannot see why this is happening.
Message 5 of 5
It may be a problem with a BT email server.
