Message 1 of 7
Openreach email
Hi all,
Just checking that an email I have received is not a scam etc as I accidentally clicked on load imaged 😞.
[email protected]
It was about full fibre coming to my area.
Thanks!
6 REPLIES 6
Message 2 of 7
Re: Openreach email
This is a BT retail customer to customer forum. It has nothing to do with Openreach which is a separate company within the BT Group.
It is not possible to say or not whether the email is a scam without knowing the full content of the email and what it was asking you to do if anything.
You would need to check with Openreach to ascertain if it is a scam or not  however the email address that you have posted appears to be genuine and as it is a no reply email address it can not be replied to so there would be no gain for any scammer.
Do not click on or reply to any links in any email that you suspect is a scam.
Crimes and scams | Openreach
Message 3 of 7
Re: Openreach email
I received a similar email. Likely a scam as Openreach are '.com' and the email is from '.co.uk'
Message 4 of 7
Re: Openreach email
I'd be interested to know how a "fibre is coming" email could possibly be a scam tbh, also a no reply email as well, hardly screams scam tbh
Message 5 of 7
Re: Openreach email
@noddle73 @
Openreach do use .co.uk
If you do an Internet search for the email address of Openreach CEO you will see the suffix is openreach.co.uk
Message 6 of 7
Re: Openreach email
...noted
Message 7 of 7
Re: Openreach email
BT use .com for its Employees and Openreach use .co.uk
At least they did when I was a CST.
