Message 1 of 5
Outlook Password Popup
I am sure there is a relevant thread here somewhere but I couldn't find with a simple search
I am getting the dreaded Outlook password popup with all six of my BT e-mail accounts that I have setup - I have tried the recommended fix of repeatedly pressing OK in the popup but even that isn't working.
Is there a permanent fix for this ?
All suggestions gratefully received!
4 REPLIES 4
Message 2 of 5
Re: Outlook Password Popup
I have the same problem, and, like you, I'm afraid, no solution.  Help!
Message 3 of 5
Hi,
I have had this issue countless times.
It seems to be an authentication issue? Are you dropping BB connectivity, browsing with a VPN? I think your best bet is to re-install outlook and see how you get on.
Message 4 of 5
No, neither of your suggestions.  I will try reinstalling.
Thanks for your help/suggestions.
Message 5 of 5
Thanks - will try but I seem to remember there was some sort of synchronisation issue that caused this - - not a problem with app on phone just Windows.
