Message 11 of 45
Re: POP3 diagnostics
Yes - exactly my problem too.....I managed to switch my iPad to IMAP without too much difficulty, as there are no important emails stored there.....but removing a pop account appearsd to risk moving a whole lot ofhistory....
Yes, it must be a BT issue?!
Message 12 of 45
Amazing - I am very pleased that someone is able to get through to BT, and they admit it must be their end! Seven days from today....it must be the end of the holidays!
Message 13 of 45
`Thank you P40 for this note.....it has seemed to me to be BT all the time!
Message 14 of 45
I'm not sure that my last post on here should be marked as a "solution".
I contacted BT Technical Support via chat again this morning to ask for an update.  I was taken through all the usual suggestions of checking my settings on outlook etc.  - lots of stock suggestions clearly copied from pre-prepared scripts.  After an hour, I asked to be passed to a manager, who told me there was no record of my chat from Friday where they stated that there was a problem with pop3 their end.
After nearly another hour, he referred the problem to their higher level email team and said it would be resolved in the next 3 -5 days.  He assured me that this time there was a record of my chat on my account.
During the course of the nearly two-hour chat, I received an email (via IMAP not POP!) saying that they had logged my "complaint".  I hadn't actually complained!  A few minutes later, I received another email saying that, if they didn't hear back from me in the next 7 days, they would consider the complaint resolved.  After finishing my chat with the manager, I received yet another email with a link to track my fault.  When I click on the link, it says that there is no account attached to my BT ID, which is rubbish.  I tried clicking the link in an incognito window, and it took me to my account, and a page saying that the tracking service was not available at the moment!
Message 15 of 45
Well done P40.
I was taken off the chat/guidance system twice last evening - so did not get nearly as far as you did. At least, you have an answer vis 3-5 days. They do wriggle a lot, don't they.
It very fortunate that I have an iPAD and phone, both on Imap and both work.
It is quite weird hacving to go to webmail to see the incoming e-mails, then being able to send from mail, and then waiting for replies on the IPAD...it should not have to be so complicated. Once again, thank you for your perseverance!
Message 16 of 45
@Peter240119
The problem may be because of a fault with the BT email server that you are connected to. I would suggest that you try turning off your BT hub for about 30 minutes and when you turn it back on it will most likely have been issued with a new IP address and hopefully connected to a different BT email server.
Message 17 of 45
Hi P40,
You got closer than any of the rest of us!
And it seems to be working again now.
Best regards
Message 18 of 45
Hello, P40
Have you solved the problem - what did you do?
And do you still have acces to all your POP3 files?
Message 19 of 45
No, it's not working for me.  Still unable to receive pop3 emails.
My old emails are stored in a local pst file on my pc, so that shouldn't be affected unless I manually delete the file.
Message 20 of 45
The only thing I did, other than wait, was to follow an early piece of advice and change the password.  I hadn't done this in a while, and I think the suggestion was that new security software takes a dim view on long-in-the-tooth passwords.
I did also try setting up an IMAP account, as a workaround.  I have to confess this was a lot easier than I was expecting.  I had thought IMAP would try to sync ALL the folders on my email client, but it only syncs messages in a specified inbox and subfolders, which is specific to the IMAP account.  You can then move messages to local folders if you wish, just like POP3.  Also, you don't have to sync all the folders you see on webmail - I used a "server-side subscription" option to NOT sync spam and trash folders.  Now I'm not sure whether to revert to POP3.
Try changing your password and/or waiting a bit longer.
Best regards
