Message 1 of 4
Two step Security log in.
Last week I reported a fault.  At some time whilst I was progressing this a screen came up telling me I now had two step authentication.  I didn't ask for it, I don't want it, and I can't remember giving my mobile no. to BT but they have it.
Most of my email is dealt with from my desk top and a lot of the time I don't even know where my mobile is (In the last three weeks I've made £1.40 worth of calls on P.A.Y.G.).
Can I refuse it?  And if so how.
3 REPLIES 3
Message 2 of 4
Re: Two step Security log in.
there are numerous posts on this subject if you use search facility on the forum
the quick answer you cannot opt out
if you use app for mail then 2 step not required
Message 3 of 4
Thank you. This evening when I logged in I went straight in with address and password only.
Message 4 of 4
@John_N
If you try it from another machine you’ll probably find you need 2FA. It gets to know how you normally log in.
