Message 1 of 5
Password authentication not supported
Anyone any idea what causes this problem? I have changed my password but I’m still getting it and can’t access my email via Apple Mail, the BT email app or the web.
4 REPLIES 4
Message 2 of 5
Re: Password authentication not supported
I suspect you have misconfigured your account to use encrypted password when authentication should be plain text as the the whole connection is encrypted.
Message 3 of 5
But that doesn’t explain why the BT email app and the BT email webpage won’t let me login.
Message 4 of 5
have you checked to see if suggestion by @licquorice is correct and if so have you changed the server settings and tried logging in again
Message 5 of 5
So, despite having no warning emails of any type it looks like BT decided my BT ID password was compromised. In desperation I thought to change the password and then change my email password (the two are different) for the 4th time in 2 days it has started working again.
Why oh why can’t BT send a text or something to give you a heads up there is a problem and direct you to sort it out?
