Message 1 of 3
Premium Mail
Hi, I'm hoping someone can help.  I have Premium Mail and several addresses.  Usually, I can log in using my primary address and then switch between addresses.  However, due to the recent changes I now have to log in and out into each one separately which is a right pain as I often access them several times a day.  Is there any way I can regain my drop down menu so as to switch easily between the addresses? thanks.
2 REPLIES 2
Message 2 of 3
Re: Premium Mail
No.
You would need to use an email client/app and set up each account in that.
The BTMail does allow you to use it as an email client by going into the setting found by clicking on your username then going to left hand side and clicking  Mail then Accounts then Add. Add the accounts you want and save . They will appear below you main account on the left hand side.
Message 3 of 3
Re: Premium Mail
Many thanks, appreciated
