Message 1 of 5
Re: Managing BT Email now migrated to EE
Hi,
not sure who or how to contact anybody about this, but having the same issue since transferring over.
4 REPLIES 4
Message 2 of 5
@4ndyR00
As you are now an EE customer, you need to post on the EE forum https://community.ee.co.uk/
EE are a separate company within the BT Group.
Message 3 of 5
 It is the BT element that i still have that isnt working though. I can see my broadband and everything has move if i login with my BT id, if i select the EE account in my bt it says manage email but then says i am not the account holder.
Message 4 of 5
Try calling or messaging the technical support team on this link Fix email | BT Help
Message 5 of 5
My problem was fixed by BT support team. They moved the email product back to my original BT account. As far as I understand the situation New EE does not offer an email account.
