Message 1 of 3
Re: Mesage on email home screen about changed settings
Hi, I was hacked and they set up rules to prevent me seeing the activity. The latest version of e-mail does not show the rules unless you know the rule name. Check the purple action button for rules - if it says "disable" then you can do this but you still can't see what you are disabling!
2 REPLIES 2
Message 2 of 3
I have moved you onto your own thread. The thread you posted on was over two years old and referred to the previous email version.
I am on the new version and I have rules set up and I can clearly see what the rule name is and can suspend/delete/edit without issue.
What device and operating system are you using and what browser are you using?
Message 3 of 3
Hi, I'm using a microsoft surface laptop, Microsoft 11 and a chrome browser with norton extension.
Although I can't see any rules I can enable / disable them. When I enable and send myself an e-mail entitled "Fraud" it doesn't reach me. If I disable rules it does - what could be happening?
