Message 1 of 6
Re: No access to my services on web and app for weeks
I have the same problem as the above unable to access my mybilling using my btconnect.com email address. has been like it for the past week since I have been trying. Your suggestion for tech guides above the Message Now button doesn't work either on any of the catogories
5 REPLIES 5
Message 2 of 6
@Charliechelseafc
 btconnect.com is BT Business email.
This the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
Message 3 of 6
Changed to residential and kept btconnect email address
Message 4 of 6
That is not possible, which would explain why it is not working.
Message 5 of 6
@Charliechelseafc
As @licquorice  has said, once you move to BT Residential, you lose access to btconnect.com. This should have been explained to you when you cancelled your business account.
Message 6 of 6
