Message 1 of 4
Re: Outgoing Email Not Working
I’ve got this problem too.
I cannot send emails from my BT email account composed on Outlook or from my iPhone when it’s using my home WiFi via a BT router.  Webmail from the desktop and mail from the phone using a 5G connection is fine.  The BT help team say it’s an issue with the email client which doesn’t sound right to me.  The problem started yesterday.  My @iCloud.com email account works fine from the phone too.
I reckon it has to be an issue at BT’s end.
3 REPLIES 3
Message 2 of 4
Yes I've had intermittent email problems from Outlook and raised complaints. After speaking to a guide on Monday, they suggested (again) that I delete my account and set it up again. But its clearly not an issue with the account or my settings or my firewall because it works occasionally via Wifi and when that stops I switch to VPN and it works for a while and then stops. Bottom line: this is a BT server issue for outgoing emails; suspect they are trialling some agentic cybersecurity AI tool and dont want to tell us about it. Since speaking to the guide, I have made no changes to my account or laptop or firewall but magically it has improved, even though the BT Guide said they hadn't made any changes their side. Suspect they are not being entirely honest.
Message 3 of 4
@MarkEL
If this is only happening while using your home broadband it may be the BT email server that you are connected to has a fault.
I would suggest that you turn off the BT hub for about 30 minutes. This should force a change of IP address and hopefully when you re-start the hub you will be connected to a different BT email server.
Message 4 of 4
I've tried that (twice) and also deleted and reinstalled Outlook.  no luck.  Nor did removing the email accounts and reinstalling them.  There is no impact to other internet functionality.  This (and the fact that  I can send mail from a phone using 5G) suggests it's got to be something that BT has (or has not!) done....
