Message 1 of 17
Re: Outlook 365 no longer working with BT mail
My "new" Outlook on a Windows11 PC has stopped sending and receiving emails from my BT email.
From searching this forum I have found that "jontheguitar" experienced this problem in June 2024 but I couldn't find how this issue was resolved.
My BT webmail account works fine but won't re-connect to Outlook.
I have tried removing BT email account from Outlook but now I cannot re-install it and have this error message:
"sign in failed. You may need an app password.  Error code: INVALID CREDENTIALS  TEMPORARILY UNAVAILABLE".
Seriously stumped here, so suggestions welcomed
16 REPLIES 16
Message 2 of 17
Use Thunderbird.
Message 3 of 17
I would prefer to get BT mail working again
Message 4 of 17
Are you presently a BT Broadband customer or are you paying for your email through a BT Premium email account or did you migrate to EE Broadband?
If none of the above your email account may have been downgraded to a BTMail Basic account which can not be used with an email client or email apps.
See link
https://www.bt.com/help/email/bt-email-products
Message 5 of 17
Thunderbird is an alternative client to Outlook, not a different mail service.
Message 6 of 17
I am a BT broadband customer with a Standard email account which gives me access to 5 BT email addresses
Message 7 of 17
Just try Thunderbird, it's free and far better than New Outlook.
https://www.thunderbird.net/en-GB/
Message 8 of 17
Thanks, but a recommendation to try an alternative is not the solution I am seeking.
Message 9 of 17
If Thunderbird or another email client works it will show that Outlook is the problem and not your BTMail account.
Message 10 of 17
Oh for goodness sake just try it. Why are you so obsessed with Outlook?
