Message 11 of 12
Re: Unable to Add or Connect an Email Account
Many thanks,  I need to be on POP 3 not IMAP.
Message 12 of 12
Went back and tried POP3 settings again and Input Port 995, at last, it worked!
Thank you very much indeed.
I believe there has been trouble with the broadband over the last few days and probably a wrench in the works.
Tanks again,
pcS
