Message 1 of 2
Re: unable to reset reply-to address since email was hacked - cannot see how to do it in settings
I am logged out of both my email addresses again, I used totally random passwords and both accounts are logged out what do i do, it is asking for a security question that won't take my answer
1 REPLY 1
Message 2 of 2
Hi @sinclair658,
If you think your e-mail has been hacked and are unable to regain access, the best thing will be to give our team a call for some further help to restore your access Fix email | BT Help
As it has happened multiple times after you have already changed password, have you run a scan on your device using your antivirus to make sure your device is protected?
Alex
