Message 1 of 2
SENT FOLDER
How long do emails stay in sent folder. Can I put a timer on it?
1 REPLY 1
Message 2 of 2
Re: SENT FOLDER
They should stay until you delete them but it is not unknown for glitches to happen and the sent contents get deleted.
There is no timer that you can set to do it using webmail. You would need to set up an email client/app which may offer the ability to do that.
