Message 1 of 8
Sending from Thunderbird to BT internet account fails
On a fairly regular basis (approx monthly), my neighbour's BT Internet emails suddenly fail to be sent from Thunderbird with a password failure. Logging on via BT webmail works OK. Inbound emails are fine. The only way to fix is to change one digit in the password in Thunderbird and the same at the BT mail end and all works again for another few weeks. Something is triggering this failure. Any suggestions would be appreciated.
7 REPLIES 7
Message 2 of 8
Re: Sending from Thunderbird to BT internet account fails
Is your friend a presently a BT Broadband customer or is he paying for his email through a BT Premium email account or did he migrate to EE Broadband?
If none of the above his email account may have been downgraded to a BTMail Basic account which can not be used with an email client or email apps.
See link
https://www.bt.com/help/email/bt-email-products
Message 3 of 8
Has been a BT Broadband and landline customer for many years.
Message 4 of 8
Is the email account set up as an IMAP or POP3 account?
When you say that incoming works OK is this on T'bird or when using webmail?
As you may know, when setting up T'bird the automatic default when entering the account password is to use the same for Incoming and Outgoing servers.
With that in mind it appears odd that only the outgoing password appears to be the problem.
Before doing anything ensure that you are using the most up to date version of T'bird and if an POP3 account ensure that you do a back up of the downloaded emails and or check that they are still on the BT servers by logging onto webmail to ensure they are still in the Inbox and can be re-downloaded.
If an IMAP account the emails showing should still be the same as those on the BT servers.
I would then remove the email account from T'bird or delete and reinstall T'bird and then set it up manually and enter all the details rather than letting it be set up with the automatic wizard. This includes entering the incoming ad outgoing passwords manually rather than using the "use the same as " option.
The settings you need are as per the following link.
Message 5 of 8
Message 6 of 8
It is an IMAP account.
Incoming is OK, it's just the outgoing when the password suddenly fails. PW the same for both incoming and outgoing. So far, since the last PW reset, it is running OK but without doubt, it will fail again.
I will check your other points when I can get access to my neighbour's desktop.
Thank you.
Message 7 of 8
Further to my previous response, T'bird is at the current latest release, that being 140.6.0esr, updated 9th December. On checking the settings as suggested everything is correct but still unable to send e-mails with a PW failure. On checking the SMTP port, it was set to 465 as expected. Out of interest, I just deleted and rewrote '465' in its place. All then suddenly worked, sending e-mails now fully functional with no error. Perhaps you could explain what might be going on here as I am at a loss.
Thank you
Message 8 of 8
No idea why it did not work but I did say " set it up manually and enter all the details rather than letting it be set up with the automatic wizard".
