Message 1 of 5
Separate single email from thread
Hi all,
I would like to forward just the last email from a long email thread but don't know how to separate them. Can someone help please? Thanks.
4 REPLIES 4
Message 2 of 5
Re: Separate single email from thread
Click on 'View' in right hand corner > Conversation view. It toggles with each press.
Message 3 of 5
Thanks for the reply. I have followed your advice and toggled to conversation view, however, I still cannot forward the last email to someone without including all of the previous emails in the thread. What I would like to do is just forward the last email, it is not necessary to include the long string of emails that are included before that point. I hope that makes sense, any ideas please?
Thanks, Normski
Message 4 of 5
You should have toggled 'From' conversation view rather than 'To' but I suspect that isn't the problem you are describing.
To forward the last email in the chain, you need to manually delete the rest in the composition window before sending.
Message 5 of 5
Thank you for your quick reply. I have done that and it worked so thanks for solving my problem.
All the best, Normski
