Message 1 of 6
Setting 2stage authentication
I have repeatedly attempted to set up 2 stage authentication. My phone number is correct
 I never receive a passcode.
Help
5 REPLIES 5
Message 2 of 6
Re: Setting 2stage authentication
Hello @DavidButland.
Thanks so much for coming here.
Please ensure the number is correct, if it is you should be able to request the passcode to be sent to your secondary destination by selecting Problems with my passcode.
More information on setting up 2 stage authentication can be found by visiting this Help page.
Katie
Message 3 of 6
1. I am certain that the number is correct
2. The email option doesn't work either
I suspect that maybe it's something to do with Firefox, but have no evidence of that.
Thanks for the suggestion, though
Message 4 of 6
Hi @DavidButland.
Thanks for the update.
Are you able to try another browser?
Katie
Message 5 of 6
I have tried to set 2 stage authentication using Opera, but do not understand how I can trigger the request. None of the Help options seem to help.
Message 6 of 6
Hi @DavidButland
Please try changing the destination number or email address to try a different one. If it still doesn't work, I recommend speaking with our technical support team, so they can look into it and raise a ticket against your account, if needed.
Chris
