Message 1 of 5
Thousands of unwanted Draft emails
Every morning I find my draft email folder is full of hundreds of draft emails. It's the same email every time - one that I sent from my phone with a photo attachment. It consumes my monthly data allowance. How can I stop this happening please?
4 REPLIES 4
Message 2 of 5
Re: Thousands of unwanted Draft emails
What size is the picture? It is possibly too large and your phone is repeatedly trying to send it, failing, and saving it as a draft for some reason.
Message 3 of 5
If it is happening on your phone I presume you are using an email app and if so which one?
Have you logged onto your BTMail account using a browser and checking to see if the email is in any of the folders there and if it is try deleting it.
Message 4 of 5
Thank you for this suggestion, I deleted it and it's stopped so I think you are right.
Message 5 of 5
Thank you, I deleted the email and it's stopped. I think it was too big possibly.
