Message 1 of 7
Transfering emails from my BT account to a flash drive.
As my user name suggests I have very little knowlege of the cyber world.
I use bt.com for emails and I now have a huge amount of mails, inluding attachments, up there on what I guess is called the BT Cloud.
I wish to download loads of them onto a Flash Drive.
Can someone out there give me instructions in non computer jargon on how to do this easily please?
...assuming it is possible to do so, that is.
6 REPLIES 6
Message 2 of 7
Re: Transfering emails from my BT account to a flash drive.
The first questions to ask are why do you wish to download them to a flash drive and what do you intend to do with them?
Message 3 of 7
Because I want to.
Why ask those questions. The reason why is not your business@
Message 4 of 7
The question is asked because there are diffefent ways of doing it depending on what you wish to do with them.
Good luck getting with further help!
Message 5 of 7
Exactly
Message 6 of 7
OK. Perhaps if that had been made clear Iin the first place I wouldn't have answered as I did.
As said, I'm thick when it comes to this stuff.
I have emails including various different types which I want to put on a flash drive so I can work on them on a non connected laptop.
Does that make sense?
Message 7 of 7
Job done thanks to one of my neighbours.
