Message 1 of 4
Two-factor Authorisation
I seem to have been trapped into setting up two-factor authorisation and it now applies to all my sub-accounts too. Neither I nor my sub-account users want it or need it. Is it possible to disable it? I can't see any way of doing it. I would be very grateful if anyone could tell me if it is possible and how?  Many thanks.
3 REPLIES 3
Message 2 of 4
Re: Two-factor Authorisation
there are numerous posts on forum identical to yours if you use search but you cannot remove the 2FA
Message 3 of 4
If you search the forum you will find many posts about this but in short, no you can not turn it off.
Message 4 of 4
OK, that certainly seems to be the case. Thanks anyway.
