Message 11 of 14
Re: Is two-step authentication now mandatory? No option to switch it off.
Obviously it was not a new email account as the email address was the one that the email was sent to and had been being used by her.
The new email password was needed because the "old" password would be known by the previous owner ie you and as the whole idea of the procedure is to transfer "ownership" of the email account it requires the password to be changed to keep the account secure for the "new" owner.
You should check in your MyBT > Your Products > Email Manage, and look for the email account to see if it is now showing in the section for friends and family of if it is still showing as one of your email accounts.
As the procedure was not completed it may just revert back to being "owned" by you. If that does not happen as I have said, you need to contact BT to get them to sort it out.
Message 12 of 14
Tried later to sync email and was asked for password.  Put in new password and it worked.  Considering this was not saved originally and timed out it is very strange.  Just waiting for BT to sort out the My Details failure.
Thank you
Message 13 of 14
@yorkley
If she has not already done it your wife now need to go into her MyBT and complete the "Your Details" > "Personal Details" then go to the "Contact Details" and enter the recovery details making sure that she uses a different email address from the the email account she is using and to enter her own mobile number.
The mobile details are what appears to be getting used for the 2FA PIN number to be sent to.
If she scrolls further down the page she will see that 2FA is turned on.
If she clicks on the "Edit 2 FA ". It will then send a PIN to her email address and  she can see where the PIN is being sent for 2FA which should be her  mobile number. If it is not her number she can change it or if it is her mobile number she can just cancel out of the edit section.
Message 14 of 14
I cannot do that as the page requests an update and then will not save the data I type in.  Reported to BT as this has not worked for over two weeks.
