Message 1 of 15
URGENT; Son locked out of email account.
My son has been locked out of his email account ('due to suspicious activity') and has phoned you and done your message service a total of 5 times now and keeps getting told to wait for a call back from tier 2 team because he doesn't have any security questions set up. They have promised he will be called on 2 different specific days with no results.
He obviously cannot join the forum himself as he needs an email address to do that with.
He needs it sorting out urgently as he flies out on holiday on Sunday and is expecting his tickets to arrive online any day.
his name is Daniel, tel; 07xxxxxxxxx  Email: [email protected]
Please Please can someone call him to get this sorted out URGENTLY.
thanks
Jill
14 REPLIES 14
Message 2 of 15
Re: URGENT; Son locked out of email account.
This is a BT residential customer to customer forum. Your post does not go to BT. The only BT staff are the forum moderators who do not necessarily read all the posts.
You need to remove your phone number and email address from your post as this is a public forum and it is also against forum rules.
Message 3 of 15
@JILLYFIN
This is a public forum, please edit out your personal details now.
If they are not removed in five minutes I will move your post out of public view.
Message 4 of 15
Please delete the email address and phone number, this is a public forum viewed worldwide. You will get more spam and junk phone calls than you know what to do with.
This is a customer to customer self help forum, you are not talking to BT.
Message 5 of 15
Is the email account a BTMail email account and was it set up from your BT Broadband account?
If it was set up from your account and you never "gifted" the email account to him, you will be able to change the password from your MyBT.
Log onto your MyBT and go to "Your Products" then "Mail, Manage".  His email address should be shown there. Click on "See Options" then 2Change Password".
Follow the prompts. If it asks for security answers it is in relation to the security answers which you provided when you set up your account.
Message 6 of 15
As per the Private Message I sent you explaining where your post went and your subsequent reply in which you mentioned you no longer have any BT products I will include some of the message here in case it helps others.
Have you tried logging onto your "old" MyBT account. It may still be active particularly because your, albeit your son's email account is still active. Try using the "MyBT" button in the banner at the top of this page.
If that doesn't work try using the "forgotten password" link below the log on boxes on the email log on page. You can use the "Email" button in the banner . Because it was set up in your account use your security answers when needed.
Message 7 of 15
Hi
thanks for your reply.  i have tried the MyBT link, i think i did have a BtID at one point when we had a bt broadband and landline plan and usually keep a note of, now we are with vodafone and dont use the landline for anything but broadband, and i think i must have had a username rather than used my email address as a log in, so the BtID is not recognising anything i try. his account is still active-he has his account synced to his phone so he can see it is still a valid account just can't access anything.
i have had a message from a moderator now confirming that he has edited the personal details off and reposted it so not sure what else we can do now.
Message 8 of 15
As you have now moved to vodaphone are you sure you still have an email address with BT?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 9 of 15
Hi Dave
yes my son and I both use our BT email accounts every day. It has been a couple of years I think since we had broadband and landline with BT.
Message 10 of 15
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They will advise you by posting on this thread.
