Message 11 of 14
Re: Unable to delete an email
Try turning off your BT hub for half an hour and when you turn it back on you will probably be issued a new IP address and hopefully be connected to a different BT email server which may allow the email to be deleted.
Message 12 of 14
Thank you for that suggestion, I'll try it out.
Message 13 of 14
This is just one email, but since BT upgraded their mail programme, I have other problems,  such as unable to complete the request, timed out (and this after just 12 seconds !
I often have to close the programme down and start again.
Message 14 of 14
Hi Silver,
I have exactly the same problem, did you manage to sort it out,
Roger
