Message 71 of 105
Re: Unable to log in to email - Help!
I do have Outlook for my hotmail email, but loathe to use it because everytime I access my hotmail I get inundated with foreign spam messages.
Message 72 of 105
Re: email certificate
@huntmj
BT are aware of the problem and have already acknowledged it on another thread
Message 73 of 105
Use a email client such as outlook desktop or mobile/tablet app and use the following email settings to connect to the BT mail server: https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Message 74 of 105
Yes just been online to technical help chat.  This is a recognised problem  to be fixed within 24 hours!
Message 75 of 105
Ok thank you
Message 76 of 105
@pumagirl123
I'm not familiar with outlook but I seem to remember in earlier versions of it you could turn automatic sync on or off for each account.
Failing that you could try one of the free clients such as Thunderbird
Message 77 of 105
SSL certificate on BT's webmail are blocked by Chrome, Chromium and Firefox.
Mail access on the mobile app is fine - so I suppose it has to do with the the webmail - web pages rather than with the email system itself - which is positive news.
Problems started  around mid-day EST today.
Message 78 of 105
Now I can't even get into my emails at all.  I changed my password and everything thinking that might have helped.     My dad said his is OK and he's on the same server.  Is there something wrong with BT or is it my laptop
Message 79 of 105
BT Email login
I am having difficulty logging in to BT webmail. I am not seeing the options on the BT.com web-site
Message 80 of 105
home.bt.com Your connection isn't private
Hi I keep getting a warning "
Your connection isn't private"
for home.bt.com
NET::ERR_CERT_COMMON_NAME_INVALID
