Message 1 of 4
Unable to send email from iPhone
I'm unable to send email from my iPhone.
Error message: NETWORK ERROR  POSIX 96
 Everything was perfect yesterday. Is this a fault on the BT side as  Gmail and Apple email are fine?
3 REPLIES 3
Message 2 of 4
Re: Unable to send email from iPhone
If you are not able to send emails on BTMail it is irrelevant that you can send emails using a different email service. They all use their own server settings and email servers.
Are you presently a BT Broadband customer or are you paying for your email through a BT Premium email account or did you migrate to EE Broadband?
If none of the above your email account may have been downgraded to a BTMail Basic account which can not be used with an email client or email apps.
See link
https://www.bt.com/help/email/bt-email-products
Message 3 of 4
It has nothing to do with BT or EE or migration to them. It turned out to be the security settings on my router which is a Three router. I dispensed with BT and EE some time ago. They are both exorbitant and BT own EE. All I have retained is email— and I have to pay for the privilege of that.
Message 4 of 4
Perhaps if you had mentioned that you were using your own router and that you were paying for your email account through a BT Premium email account an answer regarding that may have been forth coming. At least it is sorted now.
