Message 1 of 9
Upgrade email to premium from basic
I’m on basic email. How do I upgrade to premium.
many thanks.
8 REPLIES 8
Message 2 of 9
Re: Upgrade email to premium from basic
you can try  Premium email call 0808 100 6778
Message 3 of 9
You can also order it through your MyBT.
See link section about BT Premium email
https://www.bt.com/help/email/bt-email-products
Message 4 of 9
Many Thanks
James
Message 5 of 9
These instructions don't work.
Message 6 of 9
Did you call the number in the link?
Message 7 of 9
I haven't yet because I thought it should be easy to do on line. The instructions don't correspond to my screens and it just keeps going back round the same questions. There should be a link in the instructions to click and take you to the page
Message 8 of 9
OK. I'm now on Premium and I still can't send my emails. I'm on Thunderbird as my email client. I've checked all my settings. I can receive but not send
Message 9 of 9
Re: Sending emails on thunderbird
I've upgraded to premium and checked my settings but still can't send emails
