Message 2 of 4
active e. mails..
I have been having many problems with your new e mail format   Sore eyes as print is very pale , repetitive strain syndrome from excessive use of mouse....Need to click continuously as no image is apparent till this task is done  Horrid , horrid and horrid, and time consuming.  .N.F.F.P  Thank you..
Tags (2)
3 REPLIES 3
Message 1 of 4
Re: e-mailwade
i cannot find a new avatar  i do not like the gorilla
Tags (1)
Message 3 of 4
Re: e-mailwade
Avatar for where?
Message 4 of 4
Re: e-mailwade
not to worry It is all sorted now ..
