Message 1 of 6
btinternet mail on iphone
Hi, I have just this evening started getting a ‘sender address invalid’ message when trying to send emails from my btinternet account on my iphone. No problem vis the bt webmail.
I have tried the usual delete/reinstall account ttick but no luck.
gmail account working ok on iphone.
Any ideas please?
5 REPLIES 5
Message 2 of 6
Re: btinternet mail on iphone
Are you either a BT broadband customer or paying for Premium Mail?
If neither, your email account will have been downgraded to Basic Mail which is only available via webmail.
Message 3 of 6
Hi, thanks for the reply.
I am a bt broadband customer so it should be ok.
I still receive mails ok on the phone.
Thanks again
Message 4 of 6
It is probably a BT server problem. The best advice when it happens is to do nothing, especially do not change passwords or delete the account from your phone as that can cause more problems than it solves.
The first thing to do when it happens is check to see if you can log on to your email account via a web browser. If you can there is obviously nothing wrong with your password or account hence the advice to do nothing.
If the problem did not resolve its self after a day or two or in your instance where you have deleted the email account from your device you should stop your iPhone and any other devices from checking for email. The easiest way of doing that is to turn them off if you still have the account on your device or add a couple of characters to the email address so that it is not checking your account. If you have deleted the account and it is no longer on your device do not try and add it at this time.
Once you have done that, change your email password and check that you can access your email via webmail (on a browser).
If that works you should wait at least an hour to allow the servers to sync and then add the new password to your iPhone, remembering to remove any characters you may have added and again check it works. If it does then move onto the next device if you have one.
When entering the settings, make sure that in the Outgoing server you do not use the "use same as incoming" for the email address and password. Enter them manually.
If the above does not resolve the problem, when you change your BT password on an iPhone/iPad/Apple device it may only change for INCOMING mail.
To change the outgoing mail password you have to go into Settings; then scroll down to Passwords & Accounts or on older devices Mail, Contacts, Calendars. From there select the BT email account and select the account where it is listed under IMAP.
You will find the details for the account and can change the password for the Incoming server there, the outgoing mail server only shows SMTP and mail.btinternet.com You have to tap on that Primary Server in order to find where the Outgoing password is hidden so you can update it.
When setting up the email account on your device you are best to set it up manually, using "other" and ensure that you are using the correct settings as per this link.
https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Message 5 of 6
Hi,
many thanks. I will try this tomorrow.
Message 6 of 6
Thank you for all your help.
After my last post the phone stopped receiving emails as well as sending.
I turned it off, went to bed and in the morning it was back to not sending only.
I turned the phone off again, left it for 12 hours and when I turned it on again it was back to normal.
Thanks again
