Message 1 of 3
cannot compose emails
If have a new laptop. When I try to reply or compose a new email the text box is tiny and not sufficient to enter text. Still works OK on old laptop.
2 REPLIES 2
Message 2 of 3
Re: cannot compose emails
I am presuming you are using a web browser to access your email and not an email client/app.
Try changing the size/zoom of the webpage.
If using a Windows computer, start to compose then press the Ctrl key and repeatedly pressing the + key until you get the size you want.
Message 3 of 3
Many thanks, most distinguished sage,
The only way I know to access BT email is via BT.com.
Your proposed solution worked perfectly - thanks very much for taking the time to respond so promptly and clearly.
