Message 1 of 3
email Rules
I'm very much the new boy here and I was recently hacked and with help of BT am now up and running. However, the Rules under settings is now a complete blank page when before it had about 20 rules on it. Hacker obviously wiped the whole page. Can I get a set of Rules from somewhere?
All my folders also disappeared but I have discovered they are all now listed under Trash. Is there any way I can move them back to Folders?
2 REPLIES 2
Message 2 of 3
Re: email Rules
There's not a set of rules, they are created by yourself to decide how you want to deal with incoming mail. E.g if the subject contains xxx move to folder yyy etc.
If you had a list of rules that you didn't create, it was the hacker that created them to divert your mail to another address probably.
Simply drag and drop the folders to where you want them.
Message 3 of 3
Re: email Rules
Many Thanks I will try that now.
