Message 1 of 10
email address
I have recieved an email from BT asking if i want to retain my email address as follows:- Still use your email addresses?
Let us know so we don't
deactivate your email addresses
there is an attachment and i don't want to open it in case it's a scam so anyone else recieved email like this one
Dave
9 REPLIES 9
Message 2 of 10
Re: email address
If you are leaving BT it could be about what will happen when you leave but it is more likely a scam trying to get access to your email account.
Message 3 of 10
Re: email address
not leaving BT and email address it came from is [email protected] <[email protected]>
Message 4 of 10
Re: email address
Are you a BT Business user. If so you should post on the Business Forum who may be able to help.
 https://business.forums.bt.com
Message 5 of 10
Re: email address
Not a business email, i have had it since i started with BT over 20 years ago when i did have a business but wanted to keep the email address and BT said it weasn't a problem so continued to use it.
Message 6 of 10
Re: email address
I am not sure if that is a genuine BT email address as it comes from btconnect which is possibly a BTBusiness email address and not a genuine address that the company BT Buisness would use to contact customers.
It may be best to check on the business forum.
Message 7 of 10
Re: email address
@maxspadge  BT do close addresses if unused for a certain time, and I know from personal experience that shortly before closure they send a warning as you describe. But I don't recall any attachment or see any need for one so you're right to be suspicious.
Message 8 of 10
Re: email address
Use it everyday so not sure why i got email, will give them a ring when i get chance, but thanks for the advice
Message 9 of 10
Re: email address
BT confirmed in telephone call that the email is not from them so be careful if you get one and don't open the attachment.
Message 10 of 10
Re: email address
